Actually Matt, most of those photos were taken at about 3000', except for a couple near 6500-7000'. That is the highest altitude I'll ever get to. Most of my riding takes place at 500'-3500' . Alaskan's get to enjoy low altitude deep powder that few other places in the world get to. The low altitude translates to big horsepower if you've got an 800, compared to an 800 at 7000 ' in the Rockies.
You will not feel any huge performance gains from dial-a-jets if you do not ride in areas with big temp or altitude changes. All I use it for is a lifejacket and a time saver. I hate having to rejet. I have had days where it was -10F at my front door and within an hour I am at 3500' and 30F. That would definately necessitate a jet size or two. All I do is flip the cowling, turn three screws and I'm off. I have managed to ride with four main jet sizes smaller than recommended in all conditions. This translates to more throttle response and better fuel mileage.
I dialed mine in on a 0degF day and at 500' altitude on a local lake. I set mine for the second from the lowest setting at this temp and altitude. Reading the plugs I was able to lower my main jets to 150's on an XLT with 34mm carbs. It allowed me enough adjustment this season to ride from -15F (as cold as I like to ride) to 40F and up to altitudes of 5000' without a noticeable change in performance. After 5000' at 30F I began to loose H.P. and ran extremely rich. Since I was at this altitude for only an hour or so I didn't bother rejetting. That was the only time the dial-a-jets didn't have enough range to keep up. But, with 2000 miles of riding this year, I think that was pretty good.
After a top end tear down tonight I may have changed my opinion a bit. I like to yank off the cylinders every once in a while just to see how things are going inside. About every 2000 miles, or at least once a season. The new Wiseco pistons I installed last winter showed signs of over heating slightly underneath the piston crown. However, I had good piston wash and ideal carbon build up on the top of the piston, so I think I may have pushed it too hard before getting it good and warmed up ( had some mild cold seize scuffing on the intake side). I really think it happened when I rode last year at -20F and forgot to richen the dial-a-jets. No seizure, but I got close. Which sums up the curse of dial-a-jets...if you forget to adjust them and it's too cold you will end up with a lean condition and a hot engine. BUT..the way they are designed they dump fuel when they sense a lean condition and that's what probably saved my butt. Ring gap and cylinders were excellent after 1500 miles of hammer down riding, so I think the Wiseco's are all right, or at least not as much junk as some people think. Definately more carbon build up on the exhaust ports with Torco synthetic as compared to Amsoil, so I may switch back.
I'm going to pipe it this year so I really get to challenge those dial-a-jets.
http://www.mtaonline.net/~mhbs/Moorefamily/snowmobile1.html
