Guest
·I walked out Christmas morning and saw that I have water leaking....from under the engine
I just did a heater core and didn't have any anti-freeze at home so there was just water in the radiator because it USUALLY doesn't get below freezing here - except when I forget that there's no coolant in the engine on Christmas Eve.
Anyway, I check the oil and sure enough, there is milky stuff on the dipstick. Not a lot, but the Jeep has not been run since then. The water seems to be coming from around the exhaust manifold. My question is, how do I know what the cause is? I plan to clean up the engine really well and then try to spot the source of the leak. But I guess I will have to pull the head anyway? Anyone have suggestions on this? Thanks.
