Guest
·I pulled my Carter and most vacuum tubes and vacuum solenoids preparing for the Weber install. My engine is apparently from California and according to the vacuum routing chart it has a Decelerator valve. The vacuum hoses that route to the decel valve also eventually operate my shift on the fly 4wheel drive.
Question 1: Can I remove the decelerator valve and attached tubing and run direct manifold vac to the shift on the fly?
Question 2: What is the function of the decelerator valve and is it necessary to leave it installed?
