1 - 1 of 1 Posts
I am posting this mainly for reference for anyone searching for death wobble help.
The other day I developed death wobble which was set off by every bump that I hit. I recently had replaced the ball joints and gotten an alignment. I had only driven it a couple times on the road since the ball joint job and it was fine until the other day.
My setup: dana 44s, 35" tires, grand wagoneer steering, 6" monoleaf, no steering damper, track bar and sway bar attached.
Upon inspection I noticed that both ends of the front track bar were loose. Both ends of the track bar bolt into a slotted bracket. I tightened it up and took it for a test drive down a pothole-filled road. The problem seemed to be fixed.
1 - 1 of 1 Posts
