You can hook up a vacuum guage to the manifold. If it flutters fast at idle, it probably means a valve, or valve spring. Another thing to check is for hairline cracks between two cylinders in the dist cap. Cross-fire can sometimes cause this, by firing the spark plug on an open valve. If the firing order is correct, you can isolate which cylinder it is by pulling one plug wire at a time, until it goes away.
