1 - 9 of 9 Posts
I have a 98TJ with a 35 rear end.
I also have a wrecked ZJ with a aluminum 44.
Is it worth the time to put this 44 in my TJ?
Does it have the same axles and 3rd member as the cast 44?
nope. It's far from the strength of a normal D44. much closer to the strength of a D35.
What about the other way around, are there any D44 Wrangler axles that will bolt into a 99 WJ? We just bought it, and I am being timid with it because I have heard these axles aren't the best. I am running 315x75x16's and would like to find a bolt in axle if possible.
I think the Ford 9-inch from an Exploder is pretty close. You have to change suspension attachment points, but that's of no consequence. Do a search for Ford 9.
[ QUOTE ]
[/ QUOTE ]
There are TJ's with D44's, but they are Rare, or at least not as plentiful as 35's. But they won't bolt up, the Control arm mounts are different.
Thanks for the quick responses. I am going to have to do some homework on this. I can fab, but like to do as little as possible. I will check the two axles out that have been mentioned.
Official Historian
Explorers have 8.8" axles.
[ QUOTE ]
[/ QUOTE ]
yep, 8.8's and I think the width is 1" narrower, or maybe 1" each side. which isn't all that bad. good compromise for adding Disc brakes at the same time.
1 - 9 of 9 Posts
