I own a '53 Willys CJ3a , Dana 44 rear with 10 spline axleshafts. I would like to put a lock-right in this axle but
I'm not sure of the strength of the 10-spline shafts--I've heard they aren't very strong. Does anyone make a
30-spline 1-pc axleshaft conversion for this axle and if this kit exists could I put a lock-right for a D44 with
30-spline shafts in it? Thanks for your help, Erik A
on a stock willys the rear axle is bulletproof, spoa and 33's it lasted me half a year. 70 1/2 rear axles are offset diff 30 spline 44's if you can find one, if not currie or strange or anyone can probably build you an axle to put in there.
I agree with Mytzlflick, the axles are fine for a stock CJ-3. I had a Lock-right in my stock CJ-2 running 32" tires for years with no problems. I did break an axle once, but I did that trying to pull out a full size Chevy truck.
Rob
you can go 30spl and go with a warn floater no problem. this will kill two birds at once. get rid of the weaker 10spl and 2pc axles. if you dont need the hubs in the back just order the floater with drive flanges. this is much stronger than 1pc and easier to service. you will want to get rid of the 9in brakes if you have them, the floater will only work with 11in or disc.
dan
I do not intend to offend,I offend with my intent
