AustnJPR, I really don`t know how Jeepskate or anybody else did their`s but this was the easiest way for me. It`s really not hard with the AA adapter, but my tranny and tcase were sitting on my workbench when I done this. I got 6 set screws with cone shaped ends the same size as the holes in your tcase mounting flange. After removing the tcase remove the studs, usually there`s 2 of them. Install the set screws BACKWARDS, so the cone shaped ends are pointing outwards. Screw them in till the points on them barely stick out from the tcase. Install the tcase on the tranny enough so the bearing retainer on the tcase will center itself in the adapter and the set screws will meet the adapter flange. Index the tcase up where you want it and take a rubber hammer and hit the tcase so the set screws will make indentions into the adapter where you need to drill the new holes. The AA adapter has webbing cast into it so 2 of the 6 holes fell on these webs. I`ve heard about other people just using 4 or 5 bolts to hold the tcase on without any problems, but I drilled and tapped a couple holes in my tcase to be able to use 6 bolts and studs. After indexing the tcase your shifter will be pointed towards the driver side instead of upwards. Just take it somewhere that has an acetylene and get them to heat the shifter handle and bend it where you want it. You might want to take the plastic shifter handle bushings out from around the the shifter shaft before you heat it though. If you have any more questions just let me know. Hope this helps. BTW, the tranny crossmember and skid plate on my 75 is 2 separate pieces, not a 1 piece likes on your Jeep, so I wouldn`t be much help there.
Jeff
`75 CJ-5, 304, T-18/D300,
SOA w/YJ springs, D30/D44,
still under construction
