Does anyone know if the disc brakes and knuckles (6 bolt hubs) from an 82 narrow track cj will fit onto an 86 wide track dana 30? They look similar except for what appears to be a camber adjuster on the top ball joint on the narrow track. Thanks!
I changed my 75 CJ-5 to disc using wide trac axle components, the only thing I had to change was the inner bearing to a SET47(larger), machine the back of my 75 hubs, and some minor grinding to get the caliper to clear. Your 82 and 86 hubs should be the same other than the hub bolts, everything else should be the same.
wsm
