Dana 20 Xfer DUAL SHIFTER SETUP?
1 reading
1.5K views 4 replies 1 participant last post by  **DONOTDELETE**
Anyone know a good write-up how to setup DANA 20 XFER CASE FOR DUAL Shifters? Thanks
Muddynut
/wwwthreads_images/icons/cool.gif'79 CJ7 "Issues"-304-35s/wwwthreads_images/icons/cool.gif
I don't know where there's a writeup, but it's a pretty simple proposition...there are 2 shift rods coming out of the t-case, you need to take off the metal piece that connects the 2 together and hooks to the shifter, and make a bracket for 2 shifters (2 stock ones will work)...fab up a piece to connect the shifters to the shift rods, cut a bigger hole in the floor, add a 2 shifter boot, and you're done. I considered doing this when I did the T18 swap, but with a Jeep D20, you don't get anything extra...one shifter does t-case hi-lo, the other does 2wd 4wd...so you can have 2wd low, but my nicely worn t-case does that with just one lever. You need a scout D20 to get the front axle/rear axle settings.
Basic jeep rule of escalation:
The more projects you finish, the more you will begin.
The better welder you become, the more things you will find to weld.
#3 ·
Come to think of it, there is a D20 dual shifter writeup...
Wayne, Pyro II, the guy from Hawaii, has a Jeep D20 dual shifter writeup on his site, but I can't find the link. I'm sure if you e-mail him, he'd be happy to help.
#5 ·
Your the guy with the TITE Body Panels and Fenders.. I love that writeup.... Tite jeep man thanks for the information
Muddynut
