OK, here's one for you wiring guys...
My highbeam indicator is always on regardless of whether or not the headlights are on or not. The light stays on even if I unplug the indicator switch and pull the headlight fuses (or even all the fuses). The only time they go out is if I unplug BOTH headlight plugs at the headlight. This got worse today when this short made the dash clock die... Anyone got any ideas where I should begin?
Also, I'm curious if pre and post 88.5 wiring harness are the same... I can't remember if they are or not...
My brain is full - can I go home now?
