Are these axles useful for a manual CJ with front passenger diff. I know zero about axle fab. Is this more difficult than a manual 44 swap?
ok first off.. those wagoneer axles have 6 lugs vs.. 5 as on the jeep.. and the rear axle has an off center diff.. its on the passenger side.. so unless you are running the qt on your cj.. it wont work.. but you should be able to put your front d30 spindles on out onto the front 44.. to convert it to 5 lug.. and manual hubs..
