I am slowly starting to my front axle together. Step one is to get the knuckels off and send them out to get "flat topped and drilled" Here is the axle info
Came from a 1977 FSJ.
I am wondering what size the nuts on the ball joints are. I have done some research and found a listing that the upper ball joint is 1-5/16th inch and the lower ball joint is 7/8th.
Do all Jeep Dana 44s have the same size ball joints or did they change them at some time. The info I got was from a much later than 1977 D44.
If someone could conferm this 1-5/16" upper ball joint fact that would be great. I want to be fully sure because I don't have a socket that big, and I just priced them.... They are 40 bucks. I want to make darn sure I get the right one.
Thanks.
Thanks.
