Was told on a prevous post to use the front drive shaft out of a 82 cherokee for the CV joint to go in the rear of my 75 Cj5. Only problem is that it won't match up with the rear Dana 20 flange. Any idea's what flange I need to get
Cheers
Rob
Little CJ5 down under
Early 79 and older Qtrac Wags and Cherokees will have the 10 spline yoke you need on the front, J trucks work too, we just robbed one off a 78.
76 CJ5 258 w/HEI, 2.5"Lift/Rancho 9000s,T-177/Dana300/Warn 8274, Locked F&R,Mosers.......
i'm intrested in that also when you say it wont match up are you talking about the u-joints or the clearance in the yokes, or is there something else i'm missing? i wanna do this on my 78
taco
78cj7
The yokes....so you say the 79 and prior quadtratrac ones are the same as my Dana20 .The uni's are the exact same as it was just the width of the mounting points
