After seeing my last post with the custom cross member mount, I need to fix the "remedy"!
The threaded holes for the cross member are history! Would I be better off cutting a hole in the side of the frame rails, make a "nut block" (lack of better term), to weld inside the frame, then weld the access hole shut. OR. Should/could I drill all the way through the frame and use said "nut block" on top of the frame rails? Would there be a safety issue with either way? Thanks!
