ive cracked my crankcase where the oil drain screw goes in and ive taken the whole engine apart to take the part of the crankcase in to get it welded. my question is that the part im taking in has some berrings in it that i cant get out because they are pressed in. so will it hurt the berrings if the guy welds it with the berrings in?
remember that your crankcase prob gets up to 300 degree's inside, i think its less on a two stroke. the bearings should be ok as long as they dont get to hot. try a bearing puller or replace them since you have it apart
