/wwwthreads_images/icons/tongue.gif Chances are, you'll be OK....that isn't the first time that has happened./wwwthreads_images/icons/tongue.gif Speaking of putting in/taking out rod bearings....some guys out here who have a few trucks were rolling in some rod bearings in an 8V-71 Detroit Diesel. The guy under the truck could not quite get clearance for a rod end so he asks the guy topside to "jog" the starter. The guys does, and the engine roared to life....the cab is tilted forward so they can't get to the air cut-off cable control....the engine...with the pan off, and a rod completely loose....runs wild...like those Jimmys CAN do just when you least expect it.....the guys run for cover....the engine revved into never-never land and blew, seting the truck afire, which also burned down the shop/wwwthreads_images/icons/frown.gif Lesson: NEVER work on a Jimmy unless you have checked the air cut-off and know it works and that you can reach it. You only have a couple of seconds/wwwthreads_images/icons/crazy.gifto react. Aren't you glad you are just a Jeep guy?/wwwthreads_images/icons/smile.gif
