Any good way <other than running a bead> to secure my cracked shackle bracket/mount to the frame on my cj5? It looks like it has been welded once already. By the way it's the front rear spring shackle that is breaking away from the frame......
That which does not kill me only makes me stronger (or dumber).
Look real close at it, make sure it's not rust that is causing it or a cracked frame. The static mount shackle is riveted then welded, you really should not have a problem with it breaking away due to the direction of force.
Brad
ORC Land Use Section Editor
http://www.off-road.com/land
