I was changing my rear main seal on my 92 6 cyl yj last night when I noticed that just behind the seal on the side of the tranny on the top portion of the halves of the seal.....the metal behind the seal was chipped off. Is there anyway that the upper portion can be replaced or is it part of the main engine block and Im stuck leaking oil forever?
Sometimes small chunks and cracks can be repaired by welding or even JB Weld. I suggest it is worth trying one of the 2, the
engine will probably need to be removed for welding.
