Converting Waggy D44 from Vac Disco to \"Normal\"
OK, have a friend {hold the jokes, yeah I got a friend} looking to put late (87 - ish) Waggy axles under his YJ. This Waggy has a vacuum disconnect on the front diff. Planning to change the carrier anyway, so what else needs to be changed other than the cover, to make this thing a conventional style diff?
I have found a couple articles which suggest this diff might use C-Clips in the front. Not sure if this is true and how specific it is to years. But again if we are changing the carrier would this matter much other than needing either different year or aftermarket axle shafts?
BTW, I did a search plus I posted this question over on the FS board, but that board doesn't seem too active. (Only about 30 posts in the last 3 months)
Thanks for any info,
