Well I finally rebuilt my TBI with all new gaskets, new injectors and new pressure regulator and a 4 wire o2 sensor. The exhaust really stinks from what ever you call it. I finally got my laptop hooked up to get some data. Here is a list of readings.
650 RPM
45 KPA
.004 O2
5.0 TPS
Error Codes
22 TPS Low
44 O2 Lean (Oxygen Sensor)
Flag Data
Idle/cool Flag
DRP Occured (Keeps blinking)
No A/C Requested
Park/Neutral
Coolant Temp 181.3
Map 1.8 volts
TPS .7 volts
Int 128
O2 .004 volts
I have a whole bunch of raw data saved as a small txt file, but it's all chinesse to me lol.
The system went into closed loop, but then came back out. I never did redo my timing or check for vaccuum leaks with propane after the rebuild (did it before, and had a leak)
So does any of this make sense to anyone? I can send the raw data to anyone who wants to see it. I was using winaldl if that matters, but the raw data is just a small .txt file. Thanks for any input.
650 RPM
45 KPA
.004 O2
5.0 TPS
Error Codes
22 TPS Low
Flag Data
Idle/cool Flag
No A/C Requested
Park/Neutral
Coolant Temp 181.3
Map 1.8 volts
TPS .7 volts
Int 128
O2 .004 volts
