My clutch pedal when I step on it makes a godawful noise!
The mounting location for the cable at the firewall is in perfect shape, I pulled the pedal assembly apart and greased the complete shaft that the pedal pivots on, I removed the cable and thoroughly oiled it, and I have tried mounting the cable holder at different degrees in relation to the pedal thinking it may be set wrong (although this should not make a difference except in pedal travel). But as soon as any tension is applied to the cable it starts making noises as if something is rubbing really hard. The slower you move the pedal in the more noise it makes and you can feel the grabbing noise in the pedal. If you stomp the pedal very quickly you will barely hear the rubbing\grinding noise (the noise is still there only the rate at which it is generated has changed).
By the sound of it I expected to find my cable cutting into the housing or firewall but as mentioned earlier these look perfect?
Any thoughts?
Any thoughts?
