New problem! Ok so my clutch master keeps losing pressure and then i bleed it and it works perfect again. Air does come out every time i bleed but i am certain the master itself doesn't have leak as i just replaced it twice last week
It'll do that with or without the spring.No residual valve in the clutch, but gravity creates the little bit of residual pressure needed.
The springs pull the shoes back against the stop post at the top. If not for the stop, the two cup seals would touch each other and cover the fluid inlet.The same way a brake cylinder works. The spring keeps pressure on the cup (against the fluid, and drum brakes have a residual valve to keep slight pressure in the line,) keeping it flared out.
Wouldn't be if it were an external, the kind with a fork you could put a spring on. I thought it was an internal from his picture.The right way - replace the slave - but that's alot of work!
Yep, as soon as I posted that, I said Rich will show his ignorance and comment. You didn't disappoint me. You are SO predictable."""""I've never seen a Jeep with a hydraulic clutch but I have seen them on other vehicles."""""
Highly unlikely to be the problem.When you let the pedal up fast after depressing it - and you have a big spring on the pedal - the master can actually create a "suction" if it moves fast enough, faster than the slave cup moves. Remember there's also a return spring inside the Master.
If suction is created, the cup's edge collapses and sucks air in.
Yep, even if a little enters, it goes right out the inlet hole from the reservoir.... Then any air that gets past the slave cups will float upward and come out the master...
I'll post the quote for you again. YOU WERE TALKING ABOUT THE MASTER CYLINDER.So maybe you can explain a bubble that got in at the slave ...
The second quote of yours is where you say that even from the slave it will go out the master reservoir. One that entered at the master goes out easy.When you let the pedal up fast after depressing it - and you have a big spring on the pedal - the master can actually create a "suction" if it moves fast enough, faster than the slave cup moves. Remember there's also a return spring inside the Master.
Again with your reading comprehension problem.And you, as always, have not offered ANY possible cause or solution.
Hard to tell what you need. It sounds like air is getting into the system somewhere.
You probably haven't gotten any answers because you never asked a question.
Are you using any fluid? Can you see a place where the fluid is seeping out? Have you made any modifications?
You could have a leak in a hose or at a fitting. Could have a crack in a hard line. Could have a seal in a master or slave cylinder that just didn't last long. You could have debris in the system that is causing seal failure.
I'm not knowledgeable on it but I suppose you could be using a fluid that is incompatible with the seals.
It's theoretically possible for air to get in through a loose fitting or cracked line, but extremely unlikely if not impossible that it could do so without there being a copious fluid leak at that point.
Jim - air is much much thinner than water, and even thinner than brake fluid. It's not uncommon for air to get in without a fluid leak. Brakes, clutches, lots of hydraulic systems. Anything where the pressure drops to, or below atmospheric.
OR he just didn't notice anything until the clutch wouldn't disengage properly, by that time the reservoir was empty and that was the source of the air.Yeah, air is thinner than water, but with a max of 15 PSI to move it. The fluid is under much higher pressure.
But I got no answers.Are you using any fluid? Can you see a place where the fluid is seeping out? Have you made any modifications?
