My clutch master cylinder is leaking on my 93 YJ 4.0. I need to replace it and I'm looking for input. Is it difficult, what about the slave cylinder, etc. Thanks.
I recently had my clutch master cylinder replaced. I paid someone to do it because I didn't know if it was the master or slave cylinder. It didn't sound like a big deal. Although I'm not sure if/how you bleed the system. The slave cylinder on a 93 Wrangler is inside the bellhousing so you have to pull the tranny to replace it. Leaks in the slave cylinder are evidently identified by wet fluid along the bottom front edge of the bellhousing.
