I think you cut yourself off. Was that going to say after the Jeep reaches normal operating temperature,
it is fine? Sounds familiar.
Don't let the fact that I predicted it prejudges you, make sure that's the problem. I could be the choke
or something else. To check the Clifford, remove the cover and look for scrape marks on the inside. If
there are scrapes, that's at least part of the problem. You could try grinding it out with a die grinder or a
Dremel tool where the scrapes appear but it's rather thin and you don't want to ruin it. You could try
pushing it toward the side that need the clearance when you tighten it down. BEWARE - if it's touching
on the valve side and not the pushrod side, you could pop a valve spring keeper and have real trouble.
Anyone want to buy my used Clifford aluminum valve cover for a 258? Looks great, black with aluminum
ribs. Seals much better than the plastic. Buyer should live in tropical climate.
