Guest
·The oil line to the center cylinder fell off last weekend while out riding, resulting in a SMOKED piston. Cooked the piston pretty good, scored the cylinder wall on the jug pretty good. I've got the jug off and in the machine getting bored as we speak.
How do I clean all the piston, ring, and cylinder wall chips / shavings out of the bottom of the crank case? The guy at the machine shop said I should "split the case" and then proceded to take me to school saying that I have to pull the clutch off with a gear puller, use a steering wheel puller to pull the pull-chord side apart. By the time he got to talking about the ignition and timing I was pretty lost.
This is my first sled and I haven't ever done a thing to a 2-stroke. I've been through a bunch of small block Chevy's, and realize that not much of that wealth of knowledge applies here.
Can anyone give me a road map about how to clean out the bottom of the crankcase, flush the bearings, and whatever else I should do to make sure this thing goes back together properly?
Are there drain holes in the bottom of the case, so I can flush if with gas&oil mix or some other solvent?
Thanks.
Thanks.
