/wwwthreads_images/icons/tongue.gif Web pages are FAR beyond my present day computer skills. I have a the computer, but not the skills (yet). SNOJEEP is presently being re-smogged./wwwthreads_images/icons/frown.gif..the intake manifold is at the cleaners(hot tank guys) and the 2150 carb is ready to set on when the intake is back./wwwthreads_images/icons/smile.gif All the air injection is ready to install. We are building the floor riser that supports the console and provides a duct for the floor heat. Our HUPP heater (Rosser)came last week /wwwthreads_images/icons/smile.giffor the floor heat system, as well as the seat/shoulder belt systems (JCWhitney). The heater blower upgrade is done,/wwwthreads_images/icons/tongue.gif and so are the dual engine block heaters. We have a shifter ordered for the TH400 from Summit./wwwthreads_images/icons/cool.gif..it goes on the floor riser too. JUST YESTERDAY I figured out what we are going to do about the fuel filler,/wwwthreads_images/icons/smile.gif and get this....We are using a chevrolet delivery van filler housing...the housing recesses in where the RH taillight was....the stock Jeep filler neck bolts to that....all below the wheel house panel, so no cuts needed; and is connected to the tank. We will be using recessed taillights (4" truck-type) cut in below where the two surface lights used to be. Separate lamps will be bumper mounted for the backup lights. The license plate bolts to the bumper backplate and will have it's own lamp. Our fuel re-work gives us: (1) more height above the tank..(2) no 90 degree hose angles at the filler neck, since the chevy part has a nice, built-in angle to it...(3)more down-angle to help the nozzle stay in. Filling with a Jeep can should be easy now. Realistically.....we SHOULD have the SNOJEEP ready to greet Santa,/wwwthreads_images/icons/smile.gif if I don't get too busy with the paying kind of work./wwwthreads_images/icons/tongue.gif It hasn't snowed yet, but we may get it tonight. Luckily, our '97 Grand is ready to go, with the fabulous 242 unstoppable Select-Trac!/wwwthreads_images/icons/crazy.gif
