Guest
·I have an '85 CJ7 with the 258 and I noticed that it is sucking oil into the air filter housing. I think it's coming from the breather filter for the PCV valve. My PCV valve is the correct one and it's new and working properly. My friend has the same problem with his '86 CJ with the 258.
I noticed in the tech section the link "4.0L Blowing Oil Into Air Filter", but it is coming back as file not found. Any advice you can give me would be much appreciated.
