Does anybody know how to remove the column ignition switch from the column without removing the whole column from the jeep?
The ignition switch is mounted on top of the column next to the mounting bracket. And looks like this:
(hmmm sorry no picture)
Just stand on your head with the brake peddle in the eye socket and you can kind of see it. Here's what Mr. Chilton says about removing the switch:
1975-86
The ignition switch is on top of the lower part of the steering column, inside the vehicle.
1. Put the key in the lock and turn to the OFF/UNLOCKED position.
2. Disconnect the batter ground cable.
3. Detach the wire connectors at the switch.
4. Remove the switch screw.
5. Disconnect the actuating rod from the switch and remove the switch.
6. Move the switch slider all the way down the column. Move it back toward the steering wheel two clicks to center OFF/UNLOCKED position.
7. Engage the column actuation rod in the switch slider and fasten the switch down.
8. Connect the wire connectors, then the battery ground cable.
Now then if my guess is correct you really didn't want to get the switch it's self out. Did you really want to get the lock cylinder out in order to change to a different key?
Well then, that is different.
I have found that Mr. Chilton isn't exactly reliable in this area and that there are at least two different ways that the lock cylinder is held in place. Mr. Chilton says that 1976 to 1986 are the same but I'm rather sure that isn't how they were built. Either one requires that you pull the steering wheel and take the turn signal switch loose and get it out of your way. Hint: Disconnect the battery or at least the horn before you start. While my memory is rather dim about the older version the new (like 1980 to 1986) is really simple and you just stick a screw driver into a slot to get the lock to release. Maybe there is a screw in the older version. Sorry I just don't remember, but you will see whatever it takes when you get the turn signal switch out of the way.
Hope this helps.
Remember…. Keep it simple… some twit with a Torx fetish designed it.
Thank you for the help I will try it this weekend. If this does not work does anyone have a 76 to 86 JEEP CJ STEERING COLUMN for sale cheep?
· Official Curmudgeon
I wasn't sure that it was the same as my '80 so I didn't post and confuse the issue. Since it seems to be, remove the screws from the trim piece around the column, remove the electrical connectors, remove the bolts that attach the steering column and roll it upside down and you should have plenty of room to work on it.
D'oh... that is too easy. In respect of what you just wrote they should all be the same. And why didn't I think of that?
Bet you can just turn the column if you remove the bracket.
Kiss works.....
You shouldn't have to remove the bracket from the column. Just remove the two bolts that hold the bracket to the support. You may have to slide the column to one side, turn one of the bracket ears into the space in the support and then turn the rest of the way over while sliding the column to the opposite side.
Well OK....... yes that should work. I love when it's just too easy and one needs to see it.
Thanks Taz
Just for CJ7Taz
There are 10 kinds of people in the world.
Those who understand binary and those who don't.
And then there are those that understand HEX but count in octets.
