Whats happening is that the leafs are rotating in respect to each other as you turn the wheel. I had the same problem. My best bet would be that your U-bolts on your leafs are not tight enough. I would not try to tighten up the clamp with heat. If tightening the u-bolts does not help...don't worry about it. The leafs are not going anywhere.
John......southern CA
