Now that it's cooled down to t-shirt weather, I thought it'd be a good time to swap out that wore out clutch. The replacement kit I got from Napa, already had a new flywheel.
Is it a good idea to change out the old flywheel bolts like you would on a flexplate?
Another question is is it easier to pull the engine for the swap or just pull the tranny? When I had my Scout II it was easier for me to pull the engine 'cause the T19 was hard for one guy to handle alone. It would be a good time to replace the rear main seals anyway.
I figure to pull the radiator and grill off and hoist the engine with a wheeled A-frame hoist I'll be using.
Everything has been pressure washed. Anything I should be looking out for?
