Pipe Master Discount
Profiler Inc announced today that they will be running a Holiday special for its PipeMaster Tools. From noon Friday December 10th to noon Friday December 17th receive a 10% discount on each tool by writing Off-Road.com in the "comments box.". Gift wrap is included if you add Wrap in the "comments box" as well. The discount will not appear on your order, but will be calculated at the time of processing. Order today for on-time Christmas delivery.
Pipe Master is the perfect tool that every fabricator and garage builder needs to make their angles and welds perfect. It is no longer difficult or complicated to create tube joints, just press the tool onto the tube, transfer, trace, cut and weld. The PipeMaster allows you to be extremely accurate and save time with not having to re-cut or grind. See how to use a PipeMaster Tool: Pipemaster Tools on Vimeo
Get the perfect gift in a kit with common sizes, or order a size individually from ½ inch tubing to 12 inch diameter pipe. Be sure to look at PipeMaster - The Welder's Tool for Contour Fits to see the various sizes available.
