/wwwthreads_images/icons/frown.gif I just can't seem to get the picture of that rolled CJ out of my mind.....[a post by HighHood about a fatal rollover]....and what I keep seeing is that CJ tub sitting there with the rollbar still attached to it and the frame is somewhere else. I have had a couple of opportunities to "field test" rollbars in the race cars that I built when they went axles up and endo, and I can tell you that any little deficiencies in the way the rollover "system' is set up will make themselves known real quick once the rubber side of the car goes skyward. I JUST WENT through this rollbar "system analysis" with our CJ, and what worried me the most was that the rollbar was not through-bolted direct to a frame member, AND the single bolt holding the frame-to-body connection at that point was only 3/8" AND rusty to boot. Call me a paranoid and crotchety old conservative engineer, but now we have a 3/4" thick pad which acts as an anchorage for the 1/2" N.F. Aircraft-grade body-to-frame bolt, and also the two 7/16" rollbar foot bolts from the top. Additionally, the bars are connected to the new vertical "sill" which runs crossways and also welds to the thick pad./wwwthreads_images/icons/tongue.gif Seeing that CJ tub minus the chassis was a chilling confirmation of my worst fears about the way the stock CJ rollbar "system" is constructed./wwwthreads_images/icons/frown.gif
Quadra-Tracs modified While-U-Wait by the crack moonguy/wwwthreads_images/icons/wink.gif Quadra-Trac Team./wwwthreads_images/icons/tongue.gif/wwwthreads_images/icons/smile.gif
