CHEVY vs. phord
1.2K views 21 replies 4 participants last post by  **DONOTDELETE**
I've heard different things about who is better, faster, stronger, etc. But i really want to know from some experience which is FASTER stock. The 350 vortec z71, and the piece of scrap ford hammered on and painted. Comparable figures, ya know, ford 4x4 and 5.4 against above stated. 0-60, off the line, top end, just some stats. we can have fun with this...
JPC GMC Z71
I'd say the Chevy is faster, unless you cut off the tailpipe. In that case the Ford would be faster due to the decreased torque in the Chevy./wwwthreads_images/icons/laugh.gif/wwwthreads_images/icons/wink.gif/wwwthreads_images/icons/smile.gif
Evan/wwwthreads_images/icons/crazy.gif
- Contagious Off-Road -
#6 ·
Looks OK to me Scoob, what are you seeing? Also, I was curious to see if the biohazard logo in my sig is annoying to have there. The Dodge guys all have these humongous pics of their trucks in their posts, and I find that a little distracting. If my sig is annoying then I'll change it.
#7 ·
none taken shagster...but seriously, do you know any ups or downs? the stock 5.7 vortec is 260 hp and i was told the ford 5.4 have somewhere around 230-250, something like that. but there are other things that come into play, wieght of the truck, stuff like that...
red Z, Chevy's have ALWAYS been faster! it's got something to do with the placement of the disributor!
Shaggy, your biohazard symbol is not showing up at all to me, just the box around it! I know what you mean when people use a 4" X 5" pic of there truck it gets very annoying, but then again most of those dogde boys are pretty annoying anyway!
Yours is fine, (when i see it!/wwwthreads_images/icons/wink.gif)
Scooby Dooby Doo !!!
#9 ·
I would assume that the Chevy is faster, due to the higher horsepower and the fact that Chevys generally make more torque through a broader RPM range. I know that the new Silverados, even with the 5.3, are considerably faster than a comperable Ford with the 5.4.
#10 ·
Stock Vortec 5.7L is 255HP, 330 lbft of torque. I don't know about the F##d 5.4. One thing to remember is I think most F##d's came with 3.55 gears while most Chevy's have 3.73's (except my 3.42's...damn high gears). So, you'd probably take a F**d off the line, but for all out max speed, the F**d might take you. Wouldn't matter anyway since the speed-limiter kicks in at 95 or so! Anyone else know about weights?
Matt
#11 ·
oh boy! gears...my dad has tried to explain what the gears are all about...i never got it...i do know my truck has 3.42 gears...whats the diff in all that crap...how much difference?
Take the "D" off of "FORD" you get "FOUR", take the "T" off of "CHEVROLET" you still get "CHEVROLE"
#12 ·
Yikes, explaining gears isn't terribly easy. Essentially the lower the gear is (numerically higher), the easier it is for the engine to turn the wheels. That's why when you increase tire size you should lower the axle ratio to match. A ratio of 3.42 means that for every 3.42 revolutions of the pinion gear (or the driveshaft), the ring gear (or the wheels) rotates once. Here's a page that might help a little bit - http://www.autoshop-online.com/auto101/drive1.html. Hope this helps a little, but this concept is a little difficult to explain.
#13 ·
that was about what my dad said, except i understood it this time...so if i have 3.42 or whatever, its harder to turn than the 3.73's ... therefore turning the wheel slower, making it slower? so what would be better performance? 3.73? i just went from baby smooth 265/75 toyo's to 285/75bfg a/t's now, work your magic...
thank you..
#14 ·
It's not so much that it's slower because the wheel turns slower, but because it doesn't have as much mechanical advantage. Let's see, how to explain... OK, think of it like this, when you ride a mountain bike in the lowest possible gear, (smallest gear in front, largest in the rear, you can accelerate really quick, but can't go very fast, right? And if you go in the highest possible gear, you can go real fast, but can't accelerate very fast at all, right? That's basically the same idea, the first example would be of ultra low gearing (ultra high numerically), the second of ultra high gearing (ultra low numerically). The idea is to get the right balance of good acceleration and good cruising rpm when choosing gears for your truck. There's a good gear ratio calculator on ORC somewhere, I'm sure somebody will post a link to it... Off the top of my head, I would tell you to go to 4.10s, your truck will accellerate like crazy and you won't have to regear if you go to bigger tires later, but with O/D you should still be OK on the freeway.
#15 ·
Actually it's the other way around. I think it's safe to say that higher gears (lower numbers) are EASIER to turn than lower gears (higher numbers). For a given driveshaft RPM, the higher gears (lower number) will result in faster wheel rotation. For example at a driveshaft RPM of 1000, 3.42's will result in about 292 revolutions of the wheel, while 3.72's will result in about 268 revolutions of the wheel.
Hope this helps!
Matt
Matt
#16 ·
Matt, I disagree. Higher gears (lower numerically) make it more difficult for the engine to turn the wheels than lower gears. The whole idea of changing to lower gears is to make the wheels easier for the engine to turn, right? Using your own example:
In reply to:
In this example, the 3.42s would turn the wheels more revolutions than 3.73s over the same period of time. Making one revolution of a wheel takes the same amount of work to do regardless of the gearing. Work is work, different gears can't change the physical properties of the wheel or the forces (such as friction) acting on it. The logical conclusion is that more work has been done since more revolutions were made. Correct? The higher gears may turn the wheel more revolutions, but it's more difficult to actually turn them.
#17 ·
I dissagree with Matt too. After I lifted my truck and put on the 35's I still had my stock 3:43's in the diff. The truck was so guttless it wasn't even funny. I could hardly start off at all and could not spin the tires. (the truck is a standard by the way) I now have 4:10's and the truck has more balls than I would have ever guessed. I can now lay a patch so long it makes the Mustang guys say Holly Sh$t!!!!!!!
Ryan.
#18 ·
ok, so 4.10 gears...Any clue how much that crap would be to get those changed...where would someone change them? OH, just to let you know...i beat a 00 mustang off the line tonite! hell yeah...and it won't hurt anything to change those gears? and it would hall some balls? i'm liking the sound of this...you guys are the best!
#19 ·
Okay, you want comparable stats? Well, the '97-'98 version of the 5.4 Ford was rated at 230HP & struggled to keep up with the 5.7L Vortec 350 at 255HP. For '99 the Triton 5.4 was increased to 260HP & actually OUTaccelerates the 270HP Vortec 5300, and the 4.7 Toyota is quicker yet. The 5.4 Ford with its stroke of more than 4" (longer than a 454 or 460 BTW) has more torque & the Toy has less weight. For 2000, the Vortec 5300 was increased to 285HP & with proper gearing is now just a tick ahead of the Toy & Ford (Dodge BTW is a very distant 4th - a full second slower to 60 than any of the above). I've seen numerous tests comparing the "big 4" & they all point to the same thing. BTW, the Chevy does best in the comparisons when all are in 4x4 trim as it's available with 4.10's while the others aren't (well, the Dodge is, but it's just plain slow). So, that's the bottom line as things exist today /wwwthreads_images/icons/smile.gif.
TEX
http://sites.netscape.net/gumboracing
