So i posted a thread on here a while back about the 4x4 on my 2003 chev s10 pickup. Basically the 4x4 works but when you go to engague the 4x4 it dosnt seem to in! I press the button and the light stays nice and solid no flashing and you can here the clicking like it wants to go in but it wont. It will if you give it some gas and then it will make a loud grind noice and then a huge click will happen and will go in. So this weekend I tryed to look more into this problem. I first started with the vaccume and cable under the battery tray! The vaccume is working I can watch it suck in and out, but there is not alot of pressure there really, like possibly not enough to push that cable. I can move the cable with a pair of pliers attached to the end and I can pull on it and push it back in etc..(wold this cable be seized up possibly?) Now I went to pull that cable out that goes to the gear box right by the oil pan there and I got it unscrewed but when I went to pull on it, it would not come out! There is a little triangular bracket that this screws into does that have to come off?????? Any help with this would be appriciated. Have i started in the right place??????? Thanks.
