When it comes to cherokees, whats the difference between command and select trac 4x4? Also whats the diffence between full and part time 4x4? I was told that part time can only be used off-road, not on pavement, would that include not on snowy/icy roads in the winter? or dry pavement only?
You can use the part time Command Trac on snow covered roads or on other slippery road surfaces, in addition to off pavement driving. The Select Trac system has a center differential that allows 4wd High use on dry roads. Don't use the Command Trac part time system on dry road surfaces. Good Luck!! /wwwthreads_images/icons/smile.gif
