I have an 87 Jeep YJ, in the spring I had the stock Peugeut tranny replaced with an AX15. I have learned an expensive lesson about checking oil levels, and want to check the oil on this tranny. Problem is I only have manuals for Peugeut tranny.
Where is the oil level fill/check plug on an AX15??
The fill plug is on the passenger side of the trans, and has a 15/16" or 24mm headed plug. The AX15 takes a special 75-90 gear oil available from your Jeep dealer for the best shift quality. It takes almost a gallon for a drain and refill. Hope this helps.
