Can someone suggest a good replacement for the Carter BBD that is CHEAP!! Something that will mount on the stock intake or has readily available adapter.
My current situation is a stock 258, no cat, generic 10" air cleaner assembly, most emission equip gone or disabled. Also if you could recommend a good donor vehicle for the carb so I can hunt for it in a junk yard.
Don't want to spend too much on motor, because plan to go with a V8 in the long run.
Kevin Low
84 CJ7
SE Michigan
A quality rebuilt non-computerized BBD would be fairly cheap.
LarryM was working on a web article for swapping in a Rochester 2g/2gc last I heard, but I'm not sure if he's finished it yet.
Then there is the Motorcraft 2100/2150.
You could try to find a used Holley 2300 series....I think they may have come stock on some Fords.
I don't have first hand experience with any of these, but a friend swapped the above mentioned BBD from a Ford onto his YJ and was happy with the results.
jo-jo
'77 CJ5 Fozzy Locker
20 degree RTI 1250
