In reply to:
make sure that you have a good set of cables (nice low guage, mine are 0 guage), make sure that you have a good connection on the terminals, start the working vehicle, let it idle for a second, run the RPM's up to about 2500 and hold it for a minute or so, then while keeping the RPM's up start the dead one (alternator puts out more amps at rpm's than at idle and this can help overcome the starter drag). and the answer is yes, it will charge the dead battery
[/ QUOTE ]
But then again if the battery is dead dead or it is real cold outside then there is an insert to all of the above.
"Edit" while you smoke a cigarette, read a chapter of a good book, take that well earned dump, clip your finger nails, change the oil in another sled, have lunch, or just doze off for a few. "End Edit"
then while keeping the RPM's up start the dead one (alternator puts out more amps at rpm's than at idle and this can help overcome the starter drag). and the answer is yes, it will charge the dead battery "Edit" If it will take a charge "End Edit"
Good Luck
