In reply to:
Looks really mean but I wouldn't want to be that close to something that has that much strength. If it breaks it wouldn't be pretty.
[/ QUOTE ]
So you would want to be near something weaker and more likely to break?
Lil_Mudder,
I'm not sure I understand your aversion to cable, vs. chain. If you know the cable's rating, and its above
what your device is, be that an electric or hand winch, you should have no problems. Chain can acumilate
micro fractures and snap without warning. Cable you can inspect for fraying.
The only time I have seen a cable snap, is missusing it. Like trying to use it as a snatch strap and
slamming it with a moving vehicle. Or using a frayed cable. Chain will do the same. A tool used properly
won't hurt you. Look at any accident report and its always misuse, not following set limits, using a tool
thats worn out, dull, damaged...
Think about it.
