Has anybody seen or used one of those new center swaybar disconnects? I've seen two (in magazines). One was some kind of electric deal, controlled by a switch. The other (in the new JP mag I just received) has a pin you pull. Both require cutting the swaybar in half and welding the coupling halves to it. Dunno 'bout the electric one, probably cost more than I'm willing to spend anyway, and (from the photo) the pin in the manual one looks awfully weak.
I like the basic concept though, and am playing around with a design for a stronger one, which would be cable actuated from the cab (gotta get the guts to cut my swaybar in half first, though! /wwwthreads_images/icons/crazy.gif) Part of the problem is that I don't know what the loads really are (does anybody?), I can only reverse engineer the existing components to determine how strong they need to be if one side is fully compressed and the other is fully extended..... probably an unrealistic scenario; after all that's what the bar is supposed to prevent.
-Dana
Place a half full glass of water before a pessimist, optimist and an
engineer:
The pessimist says the glass is half empty.
The optimist says the glass if half full.
The engineer says the glass is too large.
-Dana
engineer:
