Guest
·Hooked up my CB. Works fine, until I start the engine, then all hell breaks loose. Loud steady constant noise, not varying with RPM. Turned off, then put key to ON position (w/o starting), noise occurred when the fuel pump was priming, then stopped. So I'm fairly convinced it's related to the fuel pump I put in about 6 months ago.
Any ideas (aside from dropping the tank to install a filter on the pump) on how to eliminate this problem? This is a YJ 4.0L.
Thanks!
otr
Thanks!
otr
