CAUTION Aaron hasn't taken his meds lately
11K views 151 replies 19 participants last post by  jeepgod
He's on a roll, so I can no longer be responsible for anything he says, and I will not claim to be his Dad anymore...:shocked:
He is speaking in tongues, and is not easily comprehended.
Pat,
What did you do to him out there?
OH, BOY :givemebeer:
#75 ·
Don't need vision... we're gonna have nitrous....
and I can see straight through the front end and look at the tires....
I was thinking of making the fire wall out of expanded steel... would that be a safety factor?
oh, and the cooler will inset in the dash between the two riders and just in front of the shifter.... bwaaaahahahahahaaaa (that was an evil laugh)
#82 ·
thick wall tube to remake my lower links...... I'm gonna go after some big heims....
and a sheet of metal for the dash.... and a sheet of metal for a top..... one case of bottled beer...... ya got any NOS rockwell wheel bearings? ..... and some seals... and ...... oh a bottle for nitrous.... and a bottle for nitrogen.. and a set of regulators.... and ......
#87 ·
how big are those lower mounts??? you might want to use some trailer hitch stock... thick.. and has 4 sides.. would nicely welded to that roc..
and i like the heater you have mounted there...
I was going to use some trailer hitch stock but: at full flex that axle moves about 40 degrees, so that lower mount has to let the shock swivel 40 each way...... and that's not a heater... it's a hair dryer when the fan is on. (the fan pulls the air out the back)
#89 ·
well, I went through and labeled all of the wires in the stock harness....
then I traced them all and made sure they were hooked up right...
then I built a firewall and a dash...
then I installed the ingition and starter switch, fuel pump, fuel lines, relays, fuse blocks bla bla bla
I hit it one time to make sure I had the wires right and the son of a b!tch started right up and idled fine....
yee haaa...
#93 ·
maybe a glove box / tool storage spot..... (cheif-boy-r-dee, and a colman flask)
I still can't believe the d@mn engine runs. Steering column will be here Friday... maybe I'll be able to drive it a little next week....
#102 ·
Yeah, we're not done yet.... I'm gonna throw 3 pieces of tube on each side and skin them... I just wanted to leave it open until I was done with the engine...
got the exhaust done and some more wiring today... the radiator plumbing is roughed in but not finished yet...
#101 ·
I almost dropped my crack pipe on my keyboard, seeing that cooler thing.
The man has his priorities fo' sho'
What would be really cool (literally) is to figure out a way to install an A/C compressor to cool the cooler and not need ice.
Ricky
#105 ·
Here's a thought about that cooler. It will need to be water tight, cause on an angle you will have water dripping on your switches and electrical stuff.....
I like it though. You need to install a dispenser for the Capt. like a water cooler and you can use those gay little cone cups everytime you need a hit.
#106 ·
Got the front drive line in.
Brakes installed and bled.
Tranny shifter installed.
OBA done.
Steering is all done (except I need to install a wheel on the column).
Radiator is plumbed and the tarus fan is wired and working.
The ALDL is working.
Guages installed.
I even wraped up the engine wiring and mounted the ecm.
Drove it today... steering the front with a wrench....
Sorry no pic's...
Lots left to do. Should be on the trail in a month .....
#117 ·
I see it, Its like in your Dentist office they have highlights magazines for the kiddies with 2 pictures side by side and you got to pick out the differences.
I do like the metal on the inside, it gives it that exo-skeleton look.
