CAUTION Aaron hasn't taken his meds lately
11K views 151 replies 19 participants last post by  jeepgod
He's on a roll, so I can no longer be responsible for anything he says, and I will not claim to be his Dad anymore...:shocked:
He is speaking in tongues, and is not easily comprehended.
Pat,
What did you do to him out there?
OH, BOY :givemebeer:
#53 ·
#56 ·
I made all of the links.
The rear is in and looks good.
The front has just the lowers hooked up and I'm about to drill in the mounting bracket for the uppers.
The front lowers are exactly the same lenght, and hooked up to the other side of the mount that the rear lowers are hooked up to. (lower arms meet under the chassis on the same piece of box frame)
The front lowers are mounted to the front axle exactly the same on each side.
I can't drill the mounts for the uppers because the axle is like 3 inches over to the passenger side??????????????????????????????
I need to take a few hours and measure everything again...
The front lowers are like 6 feet long and that lessened the triangulation. That could make using them to center a little touchy but 3" ?????
that didn't make any sence... I know...
#60 ·
you might want some more trianglization... lol.. but once you get the uppers in.. the axle should be good.. you might get some steer out of the axle when it flexes is all...
but 3"... you dorked something up.. let me guess the chassis is crooked.. :D
#61 ·
well Pat, you know how I like to get to drinking when I'm in the garage...
not to self: important measurements should be made early in the day...
I dorked something up.... found it ... fixing it...
#66 ·
got it fixed and slung on the tires and air shocks
it sits at 6'-10"
leans to the passenger side until I sit in the driver seat
I did a front Hi Steer with tripple sleved tie rod and 1-1/4" heims
I now see why all those guys use a rear sway bar.........
tomorrow is going to be a big clean up day
#68 ·
I need to do some work on that axle back there. Need's a new tie rod and the brake conversion needs to go back to 4 lug so that I can keep the rotor on the drive line side.
I will do a write up on this hi steer, it involves cutting the pinion flange off for clearence. And attaching the tie rod on top of the knuckels......
I'll get my wifes camera and take some better pic's....
#69 ·
Might be the picture, but it looks like you have about 2' of tube in front of the engine???? Why the long nose, if that's what it is?
Eidt: oh, or maybe those are the air shocks.... dman polaroid pictures.....
