Caster Shims for 5\" lift
Caster Shims.
I have a 94' samurai with the Trailmaster 3" spring under lift.
I want to add the Bonz 2" shackles to it.
What degree carter shims will I need to add?
Will I need to add drive shaft spacers?
Thanks,
David
Re: Caster Shims for 5\" lift
Well, this probably isnt the answer you want, but you can bring it get aligned and ask for the print out of the Alignment, and compare what it should be to what it is.
I've got an 88.5 zook. I added about 3 to 5 degrees of shimm on the rear axle. I did not touch the front one. There is also not enough room to install a 3/4" spacer in the rear. Nothing in the front yet either.. I think I'll install the 3/4 up front...
got zook?
http://www.geocities.com/bik3r
29x10.5x15 SS TSL *SX*, Calmini Header, SPOA, Lights, Dupicolor, Z-bar, diamond plate rockers, tubes front, rear, & sides!
