You should have a blue w/white stripe wire going to the choke. That wire goes to a blue relay ( the one towards the rear ) located beside the battery and gives you 12v to operate the choke.
the green wire going into the relay (pin 87) gives 12 volts to one side of the coil until the engine is warm
pin 30/51 is the common-it has a constant 12V
pin 87A normally closed
pin 87 normally open
Heres where my problem is, mine was unhooked : I'm guessing the pinkish wire is the other side of the coil but I can't get any voltage on it to trip the relay. depending on the function of the pink wire I don't know where to land my choke wire.
Let me know where yours connect
