I really don't have a clear answer for that one.
I know what the normal manufacturers usage guides say, and I know about the experiences we have had with tow vehicles, but I really don't have a lot of experience with customizing Jeeps.
Mine has just set in the drive way for years untouched. It had a small block ford, that was scrapped, in it when I got it, and we put a small block chevy/ TH-400/ QT back in from a junkyard donor. I was involved in a project at the time, and the shop guys did the install, and I haven't really looked at it from that point on.
I do have been getting some ideas now...... You guys are full of them.....
Check the final drive ratio. If you don't know how, the easiest way is to measure around your tires. The three things you will need to know:
X amount of inches around your tire
Y rear gear ratio
Z Transmission drive ratios, especially the high gear. (1:1 in most 4 speeds)
Can't find my formula book...... Damn. It must be at the shop.
I'll get back to you on the formula...
Anyway, if you know the final drive ratio, you can make much better informed decisions on everything about your power train.
Match Carb, Cam, Intake, Exhaust, Gear Ratios, Wheel & Tire Size, Ect,
If you aren't going to rev a 300 CID engine more than say, 3,500 RPM ever, then a little 350 to 400 CFM carb would be just perfect. And Holley makes several that 2 and 4 barrel carbs that size.
Most people don't know that the late 60's and very early 70's 350 CID neck snappers only had 410 to 530 CFM carbs.
Even the big block chevys in the first A bodies only had a 530 CFM, and that was to feed a 427 CID engine!
The biggest carb chevy put out on normal production cars was 780 CFM, and that was what NASCAR used for years.
(I know about the LS-7 and LS-8 engines, and they weren't normal production, neither were Yenko or like cars)
I have a really nice selection of HUGE carbs (only used for a few hours) that people bought and couldn't make work.
I can't keep any good used 350 to 650 carbs here. 750 & 780 CFM carbs seem to be popular again also.
I saw a guy last summer that trailered a show car in here, had a RV style torque cam (exactly what a show & go car should have) and two Holley Dominators on a tunnel ram bolted to it! Seems the chrome shop plated shut all of the passages in the venturi body and metering blocks... I think the float bowls & fuel lines can be salvaged, and the tunnel ram is nice.
Anybody want to buy a small block chevy tunnel ram with two 1150 dominators bolted to it? I'll give you his phone number....
(I have to say, that polished tunnel ram and chrome plated carbs really look good setting on his poker table in the garage! Real impressive! Looks like the table is going 200 miles an hour!)
When a fool and a wise man argue, Onlookers can't tell the difference...
