If you put a carb on an engine that has too high of a CFM rating for that engine(example: put a 500 cfm on a stock 258) can you compensate for this by restricting the air flow into the carb. Such as making the hole in the air breather smaller. Is this possible or are there other facters that I haven't considered? I am assuming that a 500 and 390 CFM carb can be made to use the same amount of gas.
87 wrangler
87 wrangler
