Re: Can\'t start my engine - I6/258, Weber, stock dist/coil
It is possible you got some water into the coil thru a small crack in the housing. Spray some WD 40 on the coil and see if that does it. While your at it, spray some on the dist. cap, plug wires etc. to be sure there is no residual moisture. Ater all this time though, that is very unlikely. Good Luck!!
xjy173
xjy173
