No. Gotta pull it. Not too bad of a job compared to the rest of the project, though. It's kind of tedious pulling the outer shafts, shift motor, inner RH shaft and tie rod end. Once all that is out, pulling the carrier is only 4 bolts and a prybar.
Jason '87YJ
(350/NP435/D300twinstick/SOA/GM14-FF-Detroit/D44/M8274)
Yeah, it isn't that bad. It took me about 2.5hrs, and I was working slowly. Just remember to torque the ring gear bolts to the proper specs. The hardest part was getting the little pin out of the carrier.
Aaron.
There is a write-up for the install at Outdoor Wire in the Jeep section.
<http://www.outdoowire.com>
Aaron
